rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Blanca_O
Jul 08, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
- May we please know the firmware version of the router and satellite? A new firmware was recently released for RBS40V. Kindly check if you have the latest firmware installed (2.3.5.6). Here's the link:
https://www.netgear.com/support/product/RBS40V.aspx#download
- What version is the Alexa app and Orbi app?
- Are there other services affected aside from the volume control?
Blanca
Community Team
- Carnold1978Dec 23, 2019AspirantHi, same here. Just bought the rbk50 with the voice satelitte. Alexa's volume is waaay to high. Can't get the volume level to go down... Help!!!
