rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Larryf6666
Jul 11, 2019Initiate
Yep exactly the same problem can’t change the volume up or down & the volume is so quiet basically it’s unusable.
michaelkenward
Jul 12, 2019Guru - Experienced User
How are you changing the volume?
Voice? "Fingers"? App?
They all work here.
- frankieg73Jul 23, 2019Initiate
I have the same problem. Unable to control voice satellite volume either in the Orbi App, or the Alexa app, or the touch control on the satellite. The volume controls do not exist in either app and the physical volume control on the satellite produces no volume changes. The sound control settings (bass, treble) exist in the apps but do not produce any change in audio. Satellite firmware V 2.3.5.6, Router firmware V 2.3.5.30, Orbi App V 2.3.7.622, Alexa App V 2.2.283059.0
- Blanca_OJul 24, 2019NETGEAR Employee Retired
- wstew17Dec 20, 2020Aspirant
I'm also unable to control volume using either voice or the slider. I am using firmware V2.6.1.4 and don't see any new updates.
- Razorback92Oct 23, 2019Initiate
Have the same issue here. Speaker function is somewhat unusable.
J
frankieg73 wrote:I have the same problem. Unable to control voice satellite volume either in the Orbi App, or the Alexa app, or the touch control on the satellite. The volume controls do not exist in either app and the physical volume control on the satellite produces no volume changes. The sound control settings (bass, treble) exist in the apps but do not produce any change in audio. Satellite firmware V 2.3.5.6, Router firmware V 2.3.5.30, Orbi App V 2.3.7.622, Alexa App V 2.2.283059.0
