rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
michaelkenward
Jul 12, 2019Guru - Experienced User
Larryf6666 wrote:
Yep exactly the same problem can’t change the volume up or down & the volume is so quiet basically it’s unusable.
How are you changing the volume?
Voice? "Fingers"? App?
They all work here.
frankieg73
Jul 23, 2019Initiate
I have the same problem. Unable to control voice satellite volume either in the Orbi App, or the Alexa app, or the touch control on the satellite. The volume controls do not exist in either app and the physical volume control on the satellite produces no volume changes. The sound control settings (bass, treble) exist in the apps but do not produce any change in audio. Satellite firmware V 2.3.5.6, Router firmware V 2.3.5.30, Orbi App V 2.3.7.622, Alexa App V 2.2.283059.0
- Blanca_OJul 24, 2019NETGEAR Employee Retired
- wstew17Dec 20, 2020Aspirant
I'm also unable to control volume using either voice or the slider. I am using firmware V2.6.1.4 and don't see any new updates.
- MstrbigDec 20, 2020Master
This is the solution that I posted earlier in this thread:
Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- Razorback92Oct 23, 2019Initiate
Have the same issue here. Speaker function is somewhat unusable.
J
frankieg73 wrote:I have the same problem. Unable to control voice satellite volume either in the Orbi App, or the Alexa app, or the touch control on the satellite. The volume controls do not exist in either app and the physical volume control on the satellite produces no volume changes. The sound control settings (bass, treble) exist in the apps but do not produce any change in audio. Satellite firmware V 2.3.5.6, Router firmware V 2.3.5.30, Orbi App V 2.3.7.622, Alexa App V 2.2.283059.0
