rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
tommyday
Aug 04, 2019Tutor
I unplug the device, then plug it back in to get the volume functioning again. This is just a workaround. The volume function should not fail, but Orbi Voice is glitchy. I have the latest patches. Even when it works, the volume slider is not smooth when adjusting volume.
