rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Blanca_O
Jul 08, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
- May we please know the firmware version of the router and satellite? A new firmware was recently released for RBS40V. Kindly check if you have the latest firmware installed (2.3.5.6). Here's the link:
https://www.netgear.com/support/product/RBS40V.aspx#download
- What version is the Alexa app and Orbi app?
- Are there other services affected aside from the volume control?
Blanca
Community Team
Carnold1978
Dec 23, 2019Aspirant
Hi, same here. Just bought the rbk50 with the voice satelitte. Alexa's volume is waaay to high. Can't get the volume level to go down... Help!!!
