rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
yesdalo
Feb 28, 2020Guide
Did you were able to fix it?
Speedtorque
Feb 28, 2020Aspirant
Not completely, I have retired mine to a less prominent location (in the study) whilst the original location now has an Orbi satellite and an Echo Show. The Amazon product is much more stable and seems to understand commands easier. Whereas the Orbi Voice can be sat beside me in the quiet study and I find myself repeating commands a lot. Occasionally I find the Alexa function is not working and I need to restart it to restore this feature. However, it it stable as a satellite.
It's a great idea for a product but poorly executed and massively overpriced. What a shame...
- kevin3151May 01, 2020Initiate
I too just bought the orbi voice speaker and updated to the latest firmware. I am having the same problems in May of 2020 long after this thread was started. Apparently software updates arent fixing it.
Volume control intermittently stops working requiring a reboot. This one is a big problem!
Also
Alexa Communication features dont work.
It wont work as a multi room spekaer
There is no way to output sound to another device or input sound from another device.
- rrossi59May 01, 2020InitiateYep. I got rid of mine.
