rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Imdfnman
Jun 14, 2020Aspirant
I also am having issues with volume control. Satellite router portion works perfect but when playing music I always lose the ability to change the volume. Cannot control with all, finger or voice. If i unplug and reconnect it starts working again but will eventually stop every time. Running most up to date software v2.5.1.2....please help as I spent a lot of money for this and this is very inconvenient
- malpracticeJul 19, 2020Aspirant
I just purchased the Orbi router with satellite containing Alexa speakers. The volume control does not work. Sound is too low to be useful in the room that it is in. Sorry I discarded packaging or I would return. Router is great but speaker on satellite is useless. This thread has gone on long enough fo Netgear to have fixed this. Very disappointed.
- michaelkenwardJul 20, 2020Guru - Experienced User
- malpracticeJul 20, 2020Aspirant
Thanks. I have several Alexa dots where volume is voice controlled. I did not realize there was a lever control. It works fine. Problem solved.
