rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
michaelkenward
Jul 20, 2020Guru - Experienced User
malpractice
Jul 20, 2020Aspirant
Thanks. I have several Alexa dots where volume is voice controlled. I did not realize there was a lever control. It works fine. Problem solved.
