rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Mstrbig
Sep 11, 2020Master
RudyFord3 wrote:As others have reported, I'm unable to control the volume on my Orbi voice satellite. Firmware is up to date. Haven't seen a post on a fix.
I posted it earlier in this thread:
Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
ohlordalltaken
Sep 25, 2020Aspirant
I must be stoopid. I've tried to enter the IP address - it asks for username and password. I have tried "admin" and "password", as well as my Orbi username (email) and that password. I am able to get into the Orbi admin site, but not this IP address on the debug page. What am I doing wrong?
- RudyFord3Sep 25, 2020AspirantHaving the same issue. Was given the info for a fix, but cannot log into the Orbi voice to apply it!
- turtlegirl76Oct 26, 2020Aspirant
The username is Admin, the password is the password for your orbi account. So it's a mix of the two things you've tried.
- michaelkenwardOct 26, 2020Guru - Experienced User
Unlikely.
The Orbi username for controlling the thing itself will be
admin
No cap.
For that the default password is:
password
Again, no caps.
Unless you have changed it. In which case it will be what you changed it too.
That may or may not be the same as an "Orbi" account, whatever that is.
