rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
SweetRed
Nov 01, 2020Aspirant
I'm having the same issue. I can't control the volume using the slider or my voice. The Alexa app doesn't even have a volume option like all my other Alexa devices.
- StylerodNov 02, 2020Tutor
SweetRed wrote:
I'm having the same issue. I can't control the volume using the slider or my voice. The Alexa app doesn't even have a volume option like all my other Alexa devices.Did you try the workaround/fix from earlier in the thread?
Kind of shocking Netgear is ignorning this.
