rrossi59
Jul 01, 2019Initiate
Orbi Voice unable to control volume or tone controls
I have an Orbi Voice set-up. All works well except the ability to control the volume or tone setting on the Sattelite Speaker. I have the device set up to use Amazon Alexa and it works fine, except...
Happy2camp
Jan 19, 2021Aspirant
Rebooting my Orbi Voice seemed to have resolved the volume control issue I experienced, at least for the time being. It appears that the Alexa App interface with the Orbi Voice is very glitchy. It is also disappointing that Multiroom audio is not supported on the Orbi Voice.
- Razorback92Jan 19, 2021InitiateJust a heads up. Rebooting works and will allow control, until it doesn’t. Then you have to reboot again. Changing the voice that Alexa uses also works. Until it doesn’t.
