Lorvau
Sep 24, 2020Guide
Orbi Voice using Alexa timer/alarm doesn't go off
I have been using my Orbi Voice Satellite Alexa feature. It has been great. Two days ago, I noticed the Alexa ability using a timer (or an alarm) no longer works (it doesn't ring or flash). Alexa ...
Jazaiden
Oct 05, 2020Initiate
I have the same exact problem.
- FoobalOct 24, 2020InitiateSame problem. Issue probably began with a firmware update a few weeks back I think
- Blanca_OOct 28, 2020NETGEAR Employee Retired
Please provide the current firmware version.
Does reverting to the previous firmware version helps?
Blanca
Community Team- DpangNov 02, 2020InitiateSimilar issue for me - snooze function triggers fast blinking cyan-blue. Will not stop until power off-on. Firmware v2.3.6.4.
