Lorvau
Sep 24, 2020Guide
Orbi Voice using Alexa timer/alarm doesn't go off
I have been using my Orbi Voice Satellite Alexa feature. It has been great. Two days ago, I noticed the Alexa ability using a timer (or an alarm) no longer works (it doesn't ring or flash). Alexa ...
Jazaiden
Oct 05, 2020Initiate
I have the same exact problem.
Foobal
Oct 24, 2020Initiate
Same problem. Issue probably began with a firmware update a few weeks back I think
- Blanca_OOct 28, 2020NETGEAR Employee Retired
Please provide the current firmware version.
Does reverting to the previous firmware version helps?
Blanca
Community Team- DpangNov 02, 2020InitiateSimilar issue for me - snooze function triggers fast blinking cyan-blue. Will not stop until power off-on. Firmware v2.3.6.4.
- FoobalNov 02, 2020Initiate
I did the best thing possible with this netgear orbi - returned it to the store where i bought!
- LorvauNov 10, 2020Guide
RBS40V: the Alexa Timer/Alarm function doesn't work with either v2.5.1.6 or v2.6.1.4
FYI - My RBR50 is/was at v2.70.70
