Lorvau
Sep 24, 2020Guide
Orbi Voice using Alexa timer/alarm doesn't go off
I have been using my Orbi Voice Satellite Alexa feature. It has been great. Two days ago, I noticed the Alexa ability using a timer (or an alarm) no longer works (it doesn't ring or flash). Alexa ...
Foobal
Oct 24, 2020Initiate
Same problem. Issue probably began with a firmware update a few weeks back I think
Blanca_O
Oct 28, 2020NETGEAR Employee Retired
Please provide the current firmware version.
Does reverting to the previous firmware version helps?
Blanca
Community Team
- DpangNov 02, 2020InitiateSimilar issue for me - snooze function triggers fast blinking cyan-blue. Will not stop until power off-on. Firmware v2.3.6.4.
- FoobalNov 02, 2020Initiate
I did the best thing possible with this netgear orbi - returned it to the store where i bought!
- LorvauNov 10, 2020Guide
RBS40V: the Alexa Timer/Alarm function doesn't work with either v2.5.1.6 or v2.6.1.4
FYI - My RBR50 is/was at v2.70.70
- ddelauneFeb 02, 2021TutorBlanca, can you please respond and let us know if this is on the list for development to fix in the next firmware release? Latest firmware still has this issue of the alarm sound not going off.
- DanielQUANTUMFeb 23, 2021AspirantHi Bianca
This thread is an urgent software fix issue. It probably has impacted the entire Orbi Alexa product
Alexa timer does not work anymore!
It is likely a software bug which goes back to at least September 2020 when the thread started.
Please get it on the list and let this thread know the Ticket number.
Thanks so much for the help!
