Lorvau
Sep 24, 2020Guide
Orbi Voice using Alexa timer/alarm doesn't go off
I have been using my Orbi Voice Satellite Alexa feature. It has been great. Two days ago, I noticed the Alexa ability using a timer (or an alarm) no longer works (it doesn't ring or flash). Alexa ...
ponchman24
May 17, 2021Initiate
Same problem here! How pathetic is it that netgear broke this and now won't fix it! I will consider another vendor next upgrade cycle.
- Soke577May 21, 2021InitiateI have the same problem how I can fix?
- Blanca_OMay 27, 2021NETGEAR Employee Retired
Hi, All,
If you're experiencing issue using Alexa Timer with the Orbi Voice Satellite, please send me a private message with your name, email address and device serial number as we may have a beta version that may help address the issue(s).
Blanca
Community Team
- intellerJun 13, 2021Apprentice
It shouldnt be a beta firmware. It should be a patch for what you broke in this firmware. Development process is broken here.
