Retired_Member
Jun 05, 2019Orbi Voice, volume controls (slider on top & voice command "Alexa volume up/down) do not respond
The volume controls on top of the Orbi Voice stop working, vol control slider on top lights up and move left and right, and voice command to change the volume have no effect. Volume stays the same. C...
Jessetgerber
Dec 18, 2019Initiate
Same issue. The speaker says it’s on volume 10 but it is very low
Alainp
Dec 21, 2019Aspirant
Hi,
I have exactly the same problem
I reboot once a day.
When will you fix this issue?
