Mhamdan
Aug 27, 2018Follower
Orbi VPN & Apple TV
Hello, I just purchased a orbi triband System with a satellite, I’m impressed by the performance however, I don’t think I like this openvpn stuff. I am trying to use ipvanish or something similar o...
eljarviso
Sep 07, 2018Luminary
What you’re looking for is VPN client functionality on your router which Orbi doesn’t support. Do a google search for any router that can run DD-WRT or Tomato firmware.
- cyberprashantSep 08, 2018Luminary
i use a r7000 running tomato firmware - they have an easy to use GUI interface that's easy to use (https://advancedtomato.com/) to flash the r7000 netgear which can be had for cheap (I got a refurbished amazon one). I plug the r7000 into the orbi.
