stevelk9999
Jul 17, 2019Tutor
ORBI VPN and Armour
I enabled VPN on my router and set up the Mynear DDNS.
This seemed simple,
I then downloaded the OPen VPN app onto my android
I then downloaded the open vpn configuration and transferred to my android device
I can ping my WAN address so I know that is correct
However, when I try to connect on the app ( Intenally on my wifi), I get waiting for server
Any suggestions?? Or do I need to be outside of the wifi?
I would post about this over on the Armor forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Thank you for your help. I posted there as well. It seems that I when I turn off wifi and use cellular I can connect. I just wanted to check before I installed the laptop/windows version
Disable Armor as well and test.
