stevelk9999
Jul 17, 2019Tutor
ORBI VPN and Armour
I enabled VPN on my router and set up the Mynear DDNS. This seemed simple, I then downloaded the OPen VPN app onto my android I then downloaded the open vpn configuration and transferred...
stevelk9999
Jul 17, 2019Tutor
Thanks. I was hesitating to mess with it while it worked.
So for the record,
1. Whether or not armor is enabled, I can connect via cell network
2. Whether or not armor is enabled, I cannot connect internally with WIFI though it doesnt matter since I can connect without VPN.
For the record I took out the Bitfender box 2 since I wanted to add VPN
I know a lot of people have asked about Bitdefender box 2 versus Armor but I cant really say. I havent noticed any speed issues or problems with either.
thanks again
stevelk9999
Jul 18, 2019Tutor
1. Thanks to this board, I have set up my orbi and open VPN at House A and it seems to be working well. I live here during the week for a temporary job.
2. I will now like to set this up at house B with another Orbi ( loyal netgear customer)
My question is I would like to use the same laptop that I take back and forth and want to know how to set up a second NETGEAR Tap adapter?
- FURRYe38Jul 18, 2019Guru - Experienced User
You should be able to use same laptop...
- stevelk9999Jul 18, 2019Tutor
thanks. DO I need to change the name of the TAP adapter? Will they both need to be named Netgear?
No sure about that. You might change the name anyways and give an intuitive name so you know what the adapter is and it's location.
