stevelk9999
Jul 17, 2019Tutor
ORBI VPN and Armour
I enabled VPN on my router and set up the Mynear DDNS. This seemed simple, I then downloaded the OPen VPN app onto my android I then downloaded the open vpn configuration and transferred...
Jul 18, 2019Guru - Experienced User
You should be able to use same laptop...
stevelk9999
Jul 18, 2019Tutor
thanks. DO I need to change the name of the TAP adapter? Will they both need to be named Netgear?
- FURRYe38Jul 18, 2019Guru - Experienced User
No sure about that. You might change the name anyways and give an intuitive name so you know what the adapter is and it's location.
