rizzy321
Feb 01, 2018Aspirant
Orbi VPN issues
Hello, I'm having issues setting up VPN on my Orbi. It seems to be a port forwarding issue. I currently use No-IP to point to my surveillance system, which is on port 80 and 8000. Orbi is s...
ktula
Feb 06, 2018Apprentice
Does VPN work with port-forwarding disabled?
st_shaw
Feb 06, 2018Master
VPN should work with no manual port forwarding entries. It's not clear what you mean because there is no option to "disable"port forwarding.
- ktulaFeb 06, 2018Apprentice
wrote:
wrote:Does VPN work with port-forwarding disabled?
From the OP:
"I currently use No-IP to point to my surveillance system, which is on port 80 and 8000. Orbi is set to forward these 2 ports to the NVR system."
I asked the OP if he had tested VPN with the his port forwarding disabled.
- st_shawFeb 06, 2018Master
wrote:I asked the OP if he had tested VPN with the his port forwarding disabled.
OK. Thanks.
