pjhacker
Sep 26, 2018Aspirant
Orbi VPN no network access
Hi,
I have setup my Orbi DDNS using the Netgear built in DDNS. I enabled the VPN service. I installed and configured OpenVPN on my Windows 10 machine. I can connect to my network just fine with the...
- Retired_MemberSep 27, 2018
I had a similiar issue until I changed the "Clients will use this VPN connection to access" option. By default mine was on AUTO which worked for a few days then stopped. I changed it to "All sites on the Internet & Home Network" and it started working again.
Sep 27, 2018Guru - Experienced User
