Retired_Member
Feb 09, 2020Orbi VPN setup generates 400 error
Orbi generates 400 error when trying to enable VPN. Armor security not enabled. Circles (not standalone) enabled. Check the ENABLE VPN tick UDP set start port to 12973 (also tried1273) tick UDP...
CrimpOn
Feb 09, 2020Guru - Experienced User
My VPN works. I chose "All sites on the Internet & Home Network" rather than "Auto".
Can you specify which Orbi router this is and the firmware release number?
(Hint: "latest" is not helpful.)
Thanks
- Retired_MemberFeb 09, 2020
Sorry - I tried to paste this into the MODEL field on the blog form, but it turned out to be a pull down.
Orbi RBR 40 ver 2.3.5.30 (No updates available)
Tried your config - All Internet, etc - same reaction -
- CrimpOnFeb 09, 2020Guru - Experienced User
Just checking (I am tediously "literal"), clicking the "Apply" button results in error 400, not "Save"?
Oh, sometimes trying a different browser helps. (I cannot remember how to "clear cache", so I just open a different web browser when I run into problems).)
