rckingsley
Dec 16, 2018Aspirant
Orbi VPN Tunnel to VPN Provider
I have an RBR50/RBS50, and would like to create a VPN tunnel to a 3rd-Party VPN company (like CyberGhost, NordVPN, etc.). I want to use a 3rf-Party VPzn service for my mobile devices when I travel, ...
thombe
Dec 17, 2018Apprentice
I use an Asus DSL-AC68U Router and have the Orbi as the "wifi part" in AP Mode.
That way I keep all the features the Asus gives me (including VPN server and client) whilst using the orbi for the improved range. Also useful in this setup for when NG release new firmwares which may require full reset of the orbi, no real effort to get the settings back up and running again.
Dec 17, 2018Guru - Experienced User
This is a great alternative solution as well.
- rckingsleyDec 24, 2018Aspirant
Thanks for the responses. I have also been looking at possibly using DD-WRT as a possible firmware alternative. This is already certified for a number of Netgear routers, but not yet for any of the 'BRxxx' series. I may (as others have suggested) actually get another router (or possibly use an old Linksys WRT1900AC router I have) to handle the actual 'Internet' routing (with external VPN support), and use the Netgear routers as more of a 'home' routing infrastructure.
It's sad that more-and-more consumers are using external VPNs to protect their privacy, but home routers have not kept pace. Ah well...
