mmillikin
Jan 28, 2018Aspirant
Orbi vs. AirPort Extreme + Nighthawk X4s extender?
I recently purchased the Nighthawk X4s Mesh Range Extender for use with existing Apple AirPort Extreme ac. The single SSID works as advertised, but the performance is still not what I was hoping for....
DarrenM
Jan 30, 2018Sr. NETGEAR Moderator
The RBK30 could be better for you but it could be a environment issue going on have you tried to find the best channel for your wifi network or moved the extender around some to find better performance?
DarrenM
- mmillikinJan 30, 2018Aspirant
Thanks, Darren. I'm constrained as to changing locations, but I will definitely fiddle around with the channels first. 2.4GHz is on auto, 5GHz is on 157...
