BrianCohen
Oct 12, 2019Aspirant
Orbi vs BT FTTP
I have the BT Youview box connected via ethernet to my Satelite Orbi unit. The router unit is connected directly to the FTTP modem. Everything seems to work fine until I try to watch any of the in...
- Oct 13, 2019
Thanks for the replies.
The IGMP option was turned on to British Telecom and V3.
I haven't tried the telnet stuff to get the bcakhaul data yet, but I may well do in the future.
Out of frustration yesterday I rang BT yet again and went through all the same routines I have to go through every time. Long nd short of it, they said if I plug the homehub in and have the router set up as an AP instead of a router, it will work. I'm not happy about it but I play along.
Re-assign the orbi router as an AP, plug the BT Homehub into the Orbi and the BTFTTP Modem and restart everything.
Humble pie time, it works a treat. No issues whatsoever, I'm even seeing vast improvements on latency from the games consoles on the network. I don't know the science of why this is so, and I'm fairly certain it shouldn't require the homehub to be in the loop, but here we are, it works.
Thanks for the advice and the replies.
CrimpOn
Oct 12, 2019Guru - Experienced User
Might be worthwhile to learn the backhaul bandwidth between router and satellite.
A brief search for "4K video bandwidth" turned up a recommendation for at least 15MB and maybe 25MB.
If you are comfortable with using telnet, you can go to the Orbi debug page: http://<ip of Orbi>/debug.htm and "Enable Telnet"
Then, open a telnet client and connect to <ip of Orbi> and enter this command:
satelliteinfo wifi
Here's the report from my Orbi:
"mac address" : "A0:04:60:0D:96:FA",
"hop" : "1",
"bridge mac" : "A0:04:60:0D:96:FA",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-67",
"backhaul macaddress" : "A0:04:60:0D:96:FD",
"backhaul phytxrate" : "877",
"backhaul phyrxrate" : "975",
"backhaul parentmac" : "A0:04:60:1C:02:39"
What does your Orbi show?
BrianCohen
Oct 13, 2019Aspirant
