Cswqueen
Aug 22, 2016Tutor
Orbi vs nighthawk R8000
what are the main differences and how is the orbi better then the nighthawk
AdamG620
Nov 01, 2016Aspirant
[quote=mdgm] You can continue to use the R8000 and place the Orbi router in AP (Access Point mode) if you want and still connect the satellite to the Orbi router.[/quote]
Can you explain what this means?
For example, I have a similar router (R7800). My Uverse Gateway is running in bridge mode and the R7800 is my wireless router. If I buy an Orbi, can I set the router to AP mode and run both the router and satellite off of my R7800 and get the same mesh network?
If I have the R7800 in the basement, would I place the Orbis halfway between the existing router and the places where I have reception challenges in the house?
Thanks!
peteytesting
Nov 01, 2016Hero
AdamG620 wrote:[quote=mdgm] You can continue to use the R8000 and place the Orbi router in AP (Access Point mode) if you want and still connect the satellite to the Orbi router.[/quote]
Thanks!
hi
you would run the r7800 with its wifi disabled and connect the orbi router to it and the orbi router would be set to ap mode eg bypassing its router , the sat works the same in both router and ap modes
as long as you have ethernet run from the r7800 to the place you want to run the orib router thats fine you can then place the sat where you want
