mandmonthego
Feb 08, 2018Follower
ORBI vs Nighthawk
I had chatted with a Netgear support person about our Nighthawk AC1900. I was hoping to extend our wifi signal to outlying areas in our yard and our barn that is about 200 feet from our router. I wa...
sdunlap01
Mar 13, 2018Guide
Thanks for the info. Right now I'm sticking with the settings I have since they are working. Should that change (again) I will take additional changes into consideration but probably won't continue to spend too much more time on this as I've lost alot of time troubleshooting these connection issues I never had to before with Nighthawk routers but time will tell
Mar 13, 2018Guru - Experienced User
AT some point, you might give Orbi a try and see how it goes. I've had good luck with mine and so have others. The next FW update will be good. Should make things better for those who haven't had good luck with theres.
Good Luck in your endeavours.
sdunlap01wrote:Thanks for the info. Right now I'm sticking with the settings I have since they are working. Should that change (again) I will take additional changes into consideration but probably won't continue to spend too much more time on this as I've lost alot of time troubleshooting these connection issues I never had to before with Nighthawk routers but time will tell
