Monte15
Aug 28, 2016Aspirant
Orbi vs. Powerline connection?
Hi there, Just curious as to which solution may make the most sense for me. Overall, I'm not looking to extend my wi-fi coverage so much as improve the throughput in certain applications. In part...
Monte15
Also, two other questions I forgot to ask:
With the smart connections, and the Orbi system determining the best of the three available bands to connect a given device to, will networked devices all be visible to one another even if they are on different bands? I assume they should since there is just one single SSID that they are connected to. I just want to verify that if, say, I have a music streamer that's connected to the satellite's 5GHz channel, and wireless speakers connected to the satellite's 2.4GHz channel, and a controller app on a mobile device connected to the router's 5GHz channel, they will all see each other and have interoperability, so long as they're all on the same SSID, correct? I had some issues with this when Verizon first updated my FiOS router and extender, which had separate SSIDs show up (one with "-5G" tacked on the end), and it caused some connectivity issues until I went in and changed it.
Finally, can the Orbi system handle legacy devices that may only support WEP encryption, while keeping the others at a WPA2 standard, or do you have to select just one security method across all connections in the system?
Thanks!
mdgm-ntgr
Aug 30, 2016NETGEAR Employee Retired
Depending on your electrical wiring there might not be suitable power points in place to put Powerline adapters to connect your devices. Those certainly are an option and with the right wiring configuration work very well. The only way to know if it will work is to try it.
Orbi is designed to provide optimal wifi performance using a dedicated band for a high performance connection between the router and the satellite. It provides excellent performance. Just place the router and satellite in good positions (we have suggestions in our KB) and go through a quick configuration process.
I would go with the Orbi.
- Monte15Aug 30, 2016Aspirant
Thank you. Since I have the Powerline already, I will give that a shot and see whether my wiring supports it.
And what about my second set of questions, regarding any Orbi smart connection visibility conflicts, and the security encryption supported?
Thanks
