CrazyMonkey2017
Dec 02, 2017Follower
Orbi vs Velop
Hi, I was hoping to get some feedback from anyone who has compared the Orbi RBK50 AC3000 (or RBK40 AC2200 - my house is under 3,000 SF so not sure if I would be OK with the RBK40 assuming it had all ...
chlst54
Feb 05, 2018Aspirant
I just got the RBK40 for about two weeks and it auto upgraded to the latest firmware. Since then, the main router is randomly rebooting about once a day. I would keep the Velop if you are not having issue with it as its not worth the hassle for a pricey system.
If you are right next to your Velop, do you get 150/150?
do you get 150/150 if plugged it via ethernet?
