edski
Nov 26, 2019Aspirant
Orbi Whole home Mesh WiFi System 3-Pack or Orbi WiFi System (RBK44)
I am evaluating either the Orbi Whole home Mesh WiFi system which has the One (1) Orbi Router (RBR50v2) Two (2) Orbi Satellites (RBS50v2) Or the Orbi WiFi System (RBK44) which has One (1) Orbi Ro...
Nov 26, 2019Guru - Experienced User
There mostly the same accept for the wireless backhaul. The 50 series carries a 1733Mbps wireless backhaul speed, while all other Orbi systems carry a 866Mbps wireless backhaul.
- edskiNov 26, 2019Aspirant
I will be using it for my home wifi. Do you think the difference in speeds make a significant\very noticable difference?
- FURRYe38Nov 26, 2019Guru - Experienced User
Kind of depends on your home size will factor in if you need more than one RBS and what kind of networking operations do you mostly do? Streaming, Gaming, general internet surfing or major downloading? Things like that.
You might start here and see what NG recommends based on home size:
https://www.netgear.com/orbi/wifi-systems.aspx
If you have a small or medium size home, you may not need two RBS. Having too much wifi or wifi signal overlap, near by can cause problems. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
You won't see any differences performance wise as the main speed rates you ever see at it's max will be 866Mbps usable by supporting wifi devices. The 1733Mbps is the connection between the RBS and RBR only and isn't usable by user devices.
House is 6200 square feet. Older New England house with built ons. (Not your modern open floor plan) Primary use is general internet, streaming, 3 teenagers always on their devices.
