MichelleOz
Jun 01, 2020Follower
Orbi Whole Home WiFi System
Hello from Sydney, Australia. I bought the Orbi Whole Home WiFi System and tried to set it up. It seemed to connect for about five minutes, then would no longer connect. I continually get a message that says 'Unable to join the network ORBIXX'. I live in a share house and my housemates who are all working from home need to access it. A few issues when trying to re-establish a connection: using the app, I 'personalised' the Orbi wi-wfi name and password to that of the existing one in the house, so I can now no longer identify or access the Orbi one separately (it shows as the house wi-fi name and password). The app also sends me into a one-way spiral of continually resetting the system up, always unsuccessfully, and there is no 'menu' on the app for any alternatives. Any advice on what to do? Please use plane or easy English were possible, I am not very 'tech literate' - thank you!
Has the previous house WiFi been turned off?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
MichelleOz wrote:Hello from Sydney, Australia. I bought the Orbi Whole Home WiFi System and tried to set it up. It seemed to connect for about five minutes, then would no longer connect. I continually get a message that says 'Unable to join the network ORBIXX'. I live in a share house and my housemates who are all working from home need to access it. A few issues when trying to re-establish a connection: using the app, I 'personalised' the Orbi wi-wfi name and password to that of the existing one in the house, so I can now no longer identify or access the Orbi one separately (it shows as the house wi-fi name and password). The app also sends me into a one-way spiral of continually resetting the system up, always unsuccessfully, and there is no 'menu' on the app for any alternatives. Any advice on what to do? Please use plane or easy English were possible, I am not very 'tech literate' - thank you!
