lokimon
Apr 10, 2020Tutor
Orbi: Why do I have to factory reset to get Attached Devices to show?
Firmeware version: V2.5.1.8 For some reason, every month or so, my Orbi loses the ability to show attached devices. And then it is factory reset time. Why? What's going on? This supe...
- Apr 13, 2020
So I didn't end up factory resetting the router. It just seemed like such a drag to figure out which device was which and reenter names for them.
Saturday and Sunday the attached devices list still said 0 satellites, 0 attached devices.
This morning I was about to bite the bullet and factory reset, but got distracted with something else.
This after I was going back to it, when lo and behold, the attached devices list started working again.
Still on V2.5.1.8
Retired_Member
Apr 10, 2020V2.5.1.8 is BAD
get rid of it
lokimon
Apr 10, 2020Tutor
What is good?
And is downgrading possible?
- Retired_MemberApr 10, 2020
lokimon wrote:
What is good?And is downgrading possible?
go to the dowload area and enter your model number
I'm running RBR50 (Orbi Router) Firmware Version 2.3.5.30 since Oct 2019
lokimon- lokimonApr 13, 2020Tutor
Still on V2.5.1.8
- FURRYe38Apr 13, 2020Guru - Experienced User
Glad it's working. Please mark your thread as solved so others will know.
Please do a backup configuration to file for safe keeping. Helps save time if a reset is needed in the future.
Enjoy. :smileywink:
lokimon wrote:So I didn't end up factory resetting the router. It just seemed like such a drag to figure out which device was which and reenter names for them.
Still on V2.5.1.8
