JCR1
Feb 03, 2018Follower
ORBI wi fi 2.4 ghz / 5ghz
Hello, My security cams and smart plugs only work on 2.4 ghz. My orbi wi fi says on my smart phone transmitting on 5ghz.. How can I get to transmit on 2.4 to pick up my cams and smart plugs thx
1 Reply
- aazVirtuoso
The Orbi transmits on both 5Ghz and 2.4Ghz. Your security cams will use the 2.4 band and your phone will use the 5ghz band - there is no problem with my phone connecting to devices on the lower band through the Orbi.
