gjayw
Jul 20, 2018Aspirant
Orbi Wi-Fi Turning Off
Noticed over the past month that the Wi-fi from the orbi is momentarily switching off & on, all devices loose the signal then pick it up again, anyone else had this issue and if so how did you resolve...
gjayw
Jul 22, 2018Aspirant
No new neighbors, carried out an RF survey(I’m a network engineer with access to some handy tools) no difference when the Chanels are changed and no interference showing yet all 18 devices lose connectivity for a short period of time, irrespective of whether they are connected to the main orbi or the satellite unit, pretty sure this is an issue with the main orbi
Jul 22, 2018Guru - Experienced User
Try changing to manual channel 1, 6 or 11.
What FW version are you using?
Distance between satellite(s) and router? Feet?
