gjayw
Jul 20, 2018Aspirant
Orbi Wi-Fi Turning Off
Noticed over the past month that the Wi-fi from the orbi is momentarily switching off & on, all devices loose the signal then pick it up again, anyone else had this issue and if so how did you resolve...
Jul 20, 2018Guru - Experienced User
Nobody else reporting anything like this.
Any other wifi nieghbors near by? if so, how many?
Try changing to manual channel 1, 6 or 11.
What FW version are you using?
Distance between satellite(s) and router? Feet?
gjayw
Jul 22, 2018Aspirant
Already tried changing to channels 1, 6 or 11.
What FW version are you using? V2.1.4.16
Distance between satellite(s) and router? Feet? - 40ft
