EchostormFury
Sep 21, 2019Apprentice
Orbi Wifi 6 (RBK852) Satellite Compatibility with RBK50, Built-In Circle Plus Support?
Do we know if the new Orbi Wifi 6 (RBK852) routers will be backward compatible with RBK50 AC3000 satellites? As the default bundle only includes 1 satellite, can I still use my 2 RBK50's still (albe...
cdswindell
Nov 23, 2019Aspirant
Did you learn more about this? I have the same question.
EchostormFury
Nov 23, 2019Apprentice
Sure did, bought one myself to find out: https://community.netgear.com/t5/Orbi-AX/Orbi-Wifi-6-AX6000-Is-a-Disaster-Do-NOT-Buy/m-p/1825409#M445
- FURRYe38Nov 24, 2019Guru - Experienced User
Not everyone agrees with that post.
EchostormFury wrote:
Sure did, bought one myself to find out: https://community.netgear.com/t5/Orbi-AX/Orbi-Wifi-6-AX6000-Is-a-Disaster-Do-NOT-Buy/m-p/1825409#M445- EchostormFuryApr 19, 2020Apprentice
Well Circle is still not built in, but I did buy the stand alone Circle Plus and it does work with the router
- FURRYe38Apr 20, 2020Guru - Experienced User
So are you using Circle with the RBS850 and your main host router is the RBR50 router. The 850 doesn't support Circle currently so there is no FW that has Circle built in. I guess the RBR750 has Armor enabled. Not sure why the 7 series got it and the 8 hasn't as of yet.
EchostormFury wrote:Well Circle is still not built in, but I did buy the stand alone Circle Plus and it does work with the router
