Baseballdad2
May 04, 2020Aspirant
Orbi WiFi 6 (RBK853) AX600
I am building a 3 story house, 5,500 sqft. I am also building a shop/apartment about 250 feet away from my house. I am considering purchased the orbi 3 pack (RBK853) AX6000, I know it covers about 7,500 sqft but I am not sure if that would reach my shop with enough signal to run WiFi electronics like TVs out at the shop. I need WiFi in my shop. What are my options for this? Could I add a cheap WiFi extender in my shop and run a Ethernet cable from my house to the shop? I do not know and would really appreciate some help with this! Thank You!
If you are building, then you already need to trench to provide electricity to the shop. As long as the trencher is on site, dig to place two PVC conduits for data cable. (One to use now, and one for whatever the heck is "de regur" in 10 years.
Local building codes will specify minimum distance between the electrical and low voltage cables.
https://www.truecable.com/blogs/cable-academy/running-ethernet-and-power-cable#
There is no WiFi router that will provide decent service at a distance of 250'. You could invest in a pair of WiFi repeaters to span the distance, but cable is better every time.
You are probably already considering this. Run as much ethernet cable as possible inside the house and plan that the location where the internet service and central router/switch/patch panel has adequate space, air flow, and electrical. Anything that can be connected with a cable is inherently better than WiFi connection. Just as the electical code requires outlets on every wall of every room, I would be thinking about ethernet jacks in every room.
Also, I would want some pathways for "future use", such as from this central location to the attic space and to the outside. That 2nd floor is going to be practically "inaccessible" once the walls and floors are sealed up.
- Baseballdad2Aspirant
CrimpOn Yes did plan on installing ethernet ports in the main areas. My main concern was getting signal to my shop. Correct me if im wrong, but I think I can purchase the 3 pack Orbi (RBK853) for just my house, but then run a line to my shop from my house that plugs into another sattelite that ill buy seperately. So 3 total sattellites. 2 in the house along with the router and then 1 in my shop that is fed from my router in my house. Since this is new construction ill just have the guys trench a line to my shop for conduit. Thoughts on this?
