Tiilller
Aug 11, 2019Follower
Orbi WiFi 6 release date or update?
I'm having a bit of confusion trying to find if Orbi will release a new system that is WiFi 6 capable or if the update will go out to the current version RBK50. I'm looking to buy a unit for my paren...
Sevo123
Aug 12, 2019Apprentice
I am waiting myself and cant find anything pretty recently that has been posted anywhere online about a date of release. There will be no update to the current units because the current units don't have the wifi 6 (AX) radios. That is a hardware upgrade not a software. I have a rbk53 unit with a additional satellite( 1rbr & 3 rbs) I need 1 more rbs my property is big but Im stuck too just waiting. Honestly best thing go to costco buy the rbk53 unit and you can return it no questions asked once the new one comes out.
Placesandspaces
Sep 01, 2019Apprentice
Just read where Orbi WiFi 6 on Tom’s Guide the following “Netgear tells us that the the Wi-Fi 6 Orbi will offer gigabit wireless speeds across the entire mesh network. This router also retains Netgear's FastLane3 technology for superior performance. Like the Nighthawk AX12, the new Orbi will be equipped to handle 12 Wi-Fi streams at once, and it'll be tri-band with a dedicated 4x4 backhaul. That means data will move swiftly and seamlessly between the various satellite units in your home for coverage in every corner on every floor.
Netgear will unveil the final version of the Wi-Fi 6 Orbi mesh router in early September. The new version of the Orbi router features tri-band support with quad stream radios for all three Wi-Fi bands; it also supports MU-MIMO and OFDMA to more efficiently handle multiple users and devices. Expect more details about the Orbi Wi-Fi 6 Mesh system — including its price — when Netgear unveils the mesh router on Sept. 6.”. Looking forward to Orbi WiFi 6 hitting the markets.
- FURRYe38Sep 01, 2019Guru - Experienced User
:smileyvery-happy:
- englishl1989Sep 04, 2019Aspirant
Has there been any update as of September 2019?
- PlacesandspacesSep 05, 2019ApprenticeAccording to to the article from Tom’s Guide website it is supposed to be unveiled or at least more information on Orbi AX come 9/6/2019. Another article I read also mentioned September as the month when it will become available as well. That is all I know so far.
- altheaSep 06, 2019Guide
This is very exciting. I have been waiting for this new Orbi system. I cannot, however, find information on whether this new one will support wired backhaul. I have ethernet running underground to a separate house that I need to connect. Does anyone know if this supports wired backhaul?
- FURRYe38Sep 06, 2019Guru - Experienced User
Im sure NG will strive to ensure ethernet backhaul will be supported. :smileywink:
