rugby49
Nov 27, 2016Aspirant
Orbi WiFi and PS4 using Wifi
Been running Orbi and the satellite for about three weeks now and have to say it is overall working extremely well in my 3100 square foot house. Just bought a new LG OLED TV so moved the gaming cons...
rugby49
Wish I could but not practical. Last resort I can move it back to second floor in the room with Orbi where it would be hard wired to router. Just ran a few more speed test. Pulled the Ps4 out of the cabinet thinking wood might be blocking signal and it was 17mbs. Put it back in cabinet and ran network test through PS4 and it was 50mbs. Seems to be all over the place. Will live with it as the XBox One S has hardware capability for 4K and UHD as well as the normal streaming.
DarrenM
Nov 30, 2016Sr. NETGEAR Moderator
Hello Rugby49
Have you tried with the latest firmware 1.4.0.16 this is a large update with alot of fixes I would suggest updating to see if you get better performance on your PS4.
DarrenM
- rugby49Dec 01, 2016Aspirant
Yes. Have the latest firmware. I will see how it goes for now. It has a connection. It is just a lot lower than I expected. When I run a speed test from my cell phone just about anywhere in the house now at the furthest point I am about 90mbs and in the room where the gaming devices are I am typically 125 - 130mbs. However on both the XBox One S and PS 4 when I check network details they connect anywhere from 9mbs to 50 mbs over wifi. Not sure how accurate the details are over console or why there would be such a difference.
- rhester72Dec 01, 2016Virtuoso
Console wifi is _terrible_, across the board - my nVidia SHIELD TV being the worst by far (latencies of 777msec sitting _next to the AP_ are not uncommon).
Best suggestion here is to either get a satellite close enough to consoles to hardwire them, or try bridging Powerline from the router to the console if you can't get a satellite close enough.
Rodney
Totally agree. I will have to look to see if Netgear has come out with the satellite only to buy. What just happened this morning and one other time two days ago is the XBox One S lost wireless connection entirely and I have to reenter the network information including the Wifi password. In the past, non Orbi days, when I downed the network for an update, reboot or loss from a power outage everything would automatically connect when the network was available. My son was also home last week for a visit and said about 2:00am EST the entire Orbi system was down and he could not connect. He had to reboot the router and reconnect his XBox to the network. Have to check to see if their are system logs in Orbi that would show what would happen. But right now if Netgear does not have a satellite to purchase I have two older powerline devices here I can use.
