TXmimi's avatar
TXmimi
Follower
May 19, 2024
Orbi WiFi and satellite password
How to factory reset WiFi router? I tried to change the advanced setting on my new ORBI router from 5mhz to 2.5mhz (because certain devices will only work on the 2.5mhz setting) and now when I try to login the WiFi, I’m being asking me for a password (which I never changed from the manufacturer default PW) in order to logon to the 2.4 mhz router. NOTE: The satellite still displays it is running at 5 mhz but I can’t get the newly changed (2.5 mhz) WiFi to logon to change the advance setting on the satellite router. Therefore, I can’t get any WiFi to work on any of my devices! Do I need to unplug the satellite router? I’m not the most experienced in dealing with these types of issues but this has me stumped and I had to revert back to my old nighthawk router (that I’m trying to replace with the ORBI) until I can figure this situation out! Any advice on how to remedy this issue?
1 Reply
  • plemans's avatar
    the Orbi line can't have separate ssids for 2.4 or 5ghz.
    some versions you can enable IoT network for 2.4ghz or 5ghz but that depends on the version you have.
    What orbi do you have?
    You also posted in the extender forum and not the orbi forum. You'd probably get better/more help in the appropriate forum.
    If you want to factory reset, push and hold the reset button for 7-15 seconds while powered on
