clarkb
Jul 12, 2020Aspirant
Orbi Wifi Android
Hi, I believe this issue is Android to Orbi. Orbi is rejecting Android connections? It is effecting all devices, phones, tablets, vodafone TV. I try and wire as many devices as possible. Over...
Jul 13, 2020Guru - Experienced User
What FW version are you using now?
Did you have the Android forget any profiles that it had attempted to conencte to then reboot the android then try again?
My Galaxy Tab S2 works well. v16 is current version of FW.
- clarkbJul 13, 2020Aspirant
Hi Furry.
All of a sudden this morning my phone connected (wifi on and mobile data on) but it takes a long time to connect. I will try and wipe the cache of all previous wifi conenctions on the phone and see if that fixes it. My wife's S8 connected last night after a Samsung update. S7, S5 and other tablets not connecting. Orbi firmware V2.5.1.16. Phone Samsung S8 G950FXXS8DTC7. I will hard rest the Orbi, update firmware and start again. That should do it.
Thanks
Clark
- FURRYe38Jul 13, 2020Guru - Experienced User
As far as I know, my other halfs S8 connects fine our Orbi RBK50 fine as well.
Hopefully a reset and setup from scratch will help.One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
