clarkb
Jul 12, 2020Aspirant
Orbi Wifi Android
Hi, I believe this issue is Android to Orbi. Orbi is rejecting Android connections? It is effecting all devices, phones, tablets, vodafone TV. I try and wire as many devices as possible. Over...
clarkb
Jul 13, 2020Aspirant
Hi Furry.
All of a sudden this morning my phone connected (wifi on and mobile data on) but it takes a long time to connect. I will try and wipe the cache of all previous wifi conenctions on the phone and see if that fixes it. My wife's S8 connected last night after a Samsung update. S7, S5 and other tablets not connecting. Orbi firmware V2.5.1.16. Phone Samsung S8 G950FXXS8DTC7. I will hard rest the Orbi, update firmware and start again. That should do it.
Thanks
Clark
Jul 13, 2020Guru - Experienced User
As far as I know, my other halfs S8 connects fine our Orbi RBK50 fine as well.
Hopefully a reset and setup from scratch will help.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
