WillCB12
Jan 04, 2022Aspirant
Orbi Wifi Calling Intermittent
Hi I've been trying to fix an issue for some time and opening portal cases were not successful. I gave up in the end as I spent many hours on the telephone with Netgear support, but I really need t...
Jan 04, 2022Guru - Experienced User
WillCB12 wrote:
Hi
I've been trying to fix an issue for some time and opening portal cases were not successful. I gave up in the end as I spent many hours on the telephone with Netgear support, but I really need to resolve as I have no mobile signal where I live.
I have 1 RBR20 router and 2 RBS20 sattelites, plugged into an EE router provided by my broadband provider.
My Wifi calling is intermittant. I have worked through several fixes including firmware updates.
Chaned Primary DNS to 8.8.8.8 and Secondary to 8.8.4.4.
Changed WIFI channels to 06 on 2.4g and 44 on 5g
Turned off 20/40 MHz coexistance
Disabled MU-MIMO
Upgraded firmware.
Does anyone have any suggestions? I have an Iphone 12 and my wife has an iphone 6s. Sometimes Wifi calling shows up, but this is rare and intermittent.
Thanks
Will
WillCB12
I have firmware v2.7.3.22 for the Router and sattelites.
The modem is an EE Smarthub, it doesnt have any model number on it at all. However Wifi calling worked perfectly on it before I turned off it's wireless network and connected my Orbi.
- FURRYe38Jan 04, 2022Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2 to see if this helps any...
- WillCB12Jan 04, 2022AspirantMany thanks - this seems to have worked but I’ll keep an eye on it for a few days.
Do I need to enable any specific security settings on the Orbi as I read that it’s quite dangerous switching on the DMZ?- FURRYe38Jan 04, 2022Guru - Experienced User
No since the Orbi has it's own firewall, the DMZ can be used if you have a double NAT condition...
