WillCB12
Jan 04, 2022Aspirant
Orbi Wifi Calling Intermittent
Hi I've been trying to fix an issue for some time and opening portal cases were not successful. I gave up in the end as I spent many hours on the telephone with Netgear support, but I really need t...
WillCB12
I have firmware v2.7.3.22 for the Router and sattelites.
The modem is an EE Smarthub, it doesnt have any model number on it at all. However Wifi calling worked perfectly on it before I turned off it's wireless network and connected my Orbi.
Jan 04, 2022Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 to see if this helps any...
- WillCB12Jan 04, 2022AspirantMany thanks - this seems to have worked but I’ll keep an eye on it for a few days.
Do I need to enable any specific security settings on the Orbi as I read that it’s quite dangerous switching on the DMZ?- FURRYe38Jan 04, 2022Guru - Experienced User
No since the Orbi has it's own firewall, the DMZ can be used if you have a double NAT condition...
- WillCB12Jan 06, 2022Aspirant
Unfortunately this hasnt worked for a sustained period - wifi calling no longer showing on my telephone. Any other suggestions? Thanks
