popcornita
Jun 16, 2019Aspirant
Orbi WiFi Disconnection Constantly
I have owned the Orbi system since mid-January and I have constantly been on the phone with technical support multilpe time for this issue to no avail. The discussions with tech support has almost b...
ekhalil
Jun 16, 2019Master
- Do you notice that the disconnections happen on devices attached to the Satellites only or even for devices attached to the Router?
- What wired devices do you have connected to Orbi?
- Do you have any mesh audio system, e.g SONOS or similar?
popcornita
All of them. The Orbi router is directly connected via ethernet to the fios modem. The individual satellites also periodically disconnect, but generally it is all devices connected to the router. The netgear orbi app also signals that the router has lost its internet connection.
