popcornita
Jun 16, 2019Aspirant
Orbi WiFi Disconnection Constantly
I have owned the Orbi system since mid-January and I have constantly been on the phone with technical support multilpe time for this issue to no avail. The discussions with tech support has almost b...
popcornita
The other wired devices connected to the orbi router is the hue and my alarm system. I don't have any other mesh system in the house.
ekhalil
Jun 16, 2019Master
- What radio channels are you using for 2.4 and 5 GHz channels?
- Also please do a wifi scan and see which channels are being used for the backhaul.
- In the wifi scan please check if the channels you are using for front- and backhaul are also being used by your neighbours.
