Krimionn
Aug 21, 2020Aspirant
ORBI wifi down when i m playing on my pc
Hi
my configuration : PC link to my box with RJ45, ORBI Base link to my box with RJ45; 2 satellite in serie.
My problem : We lost the ORBI wifi when i m playing on my PC. i must reboot the satellites and i con re-loose the wifi after that.
Why ? what is the problem?
Thx
- MstrbigMaster
Krimionn wrote:Hi
Thx
Can you be more specific? What is your box?
Are the satellites wired or wireless?
- KrimionnAspirant
the box is a box of Orange in france on fiber.
the satellites are in wireless.
The TV and the decoder TV are link by RJ45 to the last satellite.
- MstrbigMaster
Krimionn wrote:the box is a box of Orange in france on fiber.
I'm assuming since it's fiber the box is either an ONT or a router? You could plug the Orbi Router directly to the box, but plug everything else after the box, so the Orbi router handles all DHCP networking.
IWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Krimionn wrote:Hi
Thx
