PGill
Jan 14, 2020Aspirant
Orbi wifi download speed slower than Rogers
Hi guys I got Rogers Ignite internet (500 MBPS) at home with their new Ignite Gateway router/modem. I tested download speed connecting to that router's wifi usining my iphone 11 pro and iphone XR u...
Jan 14, 2020Guru - Experienced User
Your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- PGillJan 14, 2020Aspirant
Sorry, may be I was clear in my original post. Ignite router/modem has already been configured as Bridge.
- FURRYe38Jan 15, 2020Guru - Experienced User
Yes you didn't mention what mode the modem was in.
What FW version is currently loaded?
Swap Lan cable between the modem and RBR? CAT 6 is recommended.
- PGillJan 15, 2020Aspirant
I have latest firmware 2.5.1.8 on both router and Satelliet. I am using original flat white Ethernet cable provided by the manufacture.
Secondly, I don't see any issue with the LAN cable because when I test internet speed on Orbi, it is getting well ober 500 MBPS. So there is no Ethernet cable issue at all. Orbi is getting data throughput over 500 MBPS. The issue is only when it goes to wifi it gets dropped to 400 MBPS or llower. It has something to do with wifi settings on the Orbi router.
