PGill
Jan 14, 2020Aspirant
Orbi wifi download speed slower than Rogers
Hi guys I got Rogers Ignite internet (500 MBPS) at home with their new Ignite Gateway router/modem. I tested download speed connecting to that router's wifi usining my iphone 11 pro and iphone XR u...
Jan 14, 2020Guru - Experienced User
Your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
PGill
Sorry, may be I was clear in my original post. Ignite router/modem has already been configured as Bridge.
